What is the actual engine size of the vRS
Help please guys
what is the exact cubic capacity of the 1.4TSI?
ie is it 1398cc or 1440cc etc
1390cc
Cheers pal, critical info right now. Plans are in motion lol
Uprated internals? :D
What ever happended to the cupra guy that popped his engine and was rebuilding it....anyome know?
More upgrades?! Get whipping APR's arse. I want to see what the "stage 3 off the shelf" will do!
I cant remember what happened to him, I thought it was Jasonboc, but he got rid of his as far as I know....
Nope nothing to do with modifications.
The guy your on about was ibizaracebrake. His cars now back to normal
That guy had his engine rebuilt using Wagner pistons. Loba have also developed rods and pistons for anyone that's interested.
Will there be much of a gain using uprated internals? Or is it more of a safty thing to make sure it runs safly with more boost etc.......
It will allow you to run higher boost safer. Also they will probably be lighter weight as they're made from better material thus allowing the engine to pick up revs quicker. This is particularly noticeable with light weight cams.
anyone working on new cams etc for these engines?
Not to my knowledge. I've spoken with a fair amount of cam specialists and the reason not is people just remap Turbo cars for good gains. Main market for cams are n/a cars like civics.
Im sure theres one of the europian guys on here running uprated cams.......
Thats what i thought as well, until i spoke to them about it. You supply them with a rod and a piston, and they will produce a set of them from the dimensions of the parts you gave. Thats not what i would call a developed product
cams ruin tickover at idle. As said above its normally NA engine territory and it normally drastically changes the power band. Theres many better ways to make power on a forced induction engine.
If i go for uprated internals ill probably run a lower compression i think
That does seem pretty pointless. May aswell stick with OEM and save the pennies towards proper developed parts.
or a properly developed car
