help needed
hi all im new to this site but heard alot of good things ;)
anyways i drive amk4 golf gttdi pd130 it alovely motor but its driving me mad atm. after shall we say driving it hard it plooms out white smoke and you can smell burnt oil.
its had 2 new turbos in the last 2 month, all breathers are clear and oil is were oil is supposed to be but i think it may have high ccv?
the problems only started since first turbo whent in may, ive had inlet manfold cemicly cleaned and cleaned all inlet pipes and ic. itsgot full turbo back miltek non res exhuast so no cat or mid box to gather old oil. during normal driving the car is fine its just when it gets warm.
if anyone could shine a little light to the problem ide be much appretiative
thanks ash
I hope someone here can help you. Welcome!
sounds like a third turbo mate, or otherwise head or gasket, if only when warm your temp sender could be up the creak.
Have your temp readings been behaving?
Edited by Lofty79
When you changed the turbo, did you change the oil feed pipe?
If the oil feed pipe is restricted, every turbo you put in will have a short life.
Hello ash and welcome along :thumbup:
