Fabia Vrs Digital Speedo
" Is this Possible " Can the MKII Fabia be turned Australian. ( Vrs DSG with Maxi Dot)
If it has maxidot yes but you need access to vcds to change it
Looking to do this too. Got the codes for the XDS and brakes just need this one
It's easy done another one today my mates new polo gti
Instruments, coding, long coding helper and it's the first thing to pop up change GB to AUS
Then change settings in maxi dot to imperial units as it changed them to metric, and turn Alt speed off
I've also had this done, Much quicker to spot your speed than the dial !
can this be done on non maxidot?
In a word, No, sorry maxi dot needed
