ASR light
Hey guys. Cleaned my maf meter today and now it feels better?
Will be a fault in either engine or ABS, need a friendly member with VAG COM to have a look for you.
Hey guys. Cleaned my maf meter today and now the ASR light is on constantly, and the on/off button has no effect. I've tried reseting the ecu and it seemed to work at first, but after about 30 secs it's back on again. What have I done this time?
How did you clean the MAF? what is safe to use?
JD
ASR light on (ESP in my case) is a classic sign of a knackered MAF I'm afraid. Either swap the MAF with a known-good item, if you can, or get someone with diagnostics equipment to have a look.
Oh, and beware: the ASR really *is* disabled, even though the fault is simply that the engine can't quite read how much air it's getting. Even more bizarre when ESP is disabled for the same reason :rolleyes:
JD
I'd advise waiting a while to see what has caused Octavia Red's problem before trying his technique, whatever it was, with your car ;)
Hi all. I used alchohol to clean the maf. Seems to be recommended for cleaning these things.
