A little help with misfire/surging
Hello there,
I took your advice and had my ECU remapped by REVO with stage 1(skoda octavia vrs 2002).
However the problem seems to be still there. The car is surging/misfiring on quick acceleration.
I scanned the car with VCDS lite and got this:
Address 01: Engine Labels: 06A-906-032-AJQ.LBL
Controller: 06A 906 032 HP
Component: 1.8L R4/5VT 0001
Coding: 11500
Shop #: WSC 02629
VCID: 73995CCF52BB
TMBER21U638669761 SKZ7Z0B1442308
5 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-00 - Please Register/Activate
16685 - Shareware Version. To Decode all DTCs
P0301 - 35-00 - Please Register/Activate
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
16955 - Shareware Version. To Decode all DTCs
P0571 - 35-00 - Please Register/Activate
Readiness: 0000 0000
I have new coils and spark plugs and have tried changing them between but the VCDS always says it is misfire on cylinder 3.
When I unplug the MAF the car runs fine but much less power.
I have new N75, new forge recirc valve and the SPS device from revo :)
I am considering chaning the tip, maf and map sensor to try to fix this. I dont think there is a leak but Im not 100% sure.
Any thoughts? Should I maybe change the fuel ignitons?
Any help is very much appreciated, Thanks!!
Edited by Poweraderz
if the misfire does not move with plug/coilpack then you need to look at the coil pack wiring. they get brittle due to the heat and crack/peal causing shorts to the rockercover. Pikey fix is to check and wrap with Electrical tape :D some people actually spend money on new looms and flashy heat shields.
oh okay I didnt realize that could be the problem! Thanks mate I will check this and keep you informed haha :D
