Steering adaption and Address 09: Cent. Elect. fault
I am looking to adapt the power steering assistance on my 56 plate 1.4TDI, but am unsure of the correct format. Currently the setting is 10110 and assume that the 4th digit is the one to change i.e. 10120, 10130 etc but am unsure as the main topic on VCDS adaptions quotes a format 000121 where the 5th digit has to be changed, i.e. 000151. - Will increasing the number make the steering lighter or heavier?
I also have an error message:-
Controller: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 25614
Shop #: WSC 13765
2 Faults Found:
01117 - Generator Terminal DF Load Signal
27-00 - Implausible Signal
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
I know from experiance last winter that the cranking speed is down, and while changing the battery eased the problem, I was always waiting for it to not start.
Edited by KeithCheetham
I recoded my Fabia's power steering from 10120 to 10140 for heavier steering.
The other fault is the common wiring issue at the two pin plug in front of the gearbox. Wire will be either broken or corroded.
