20mm Spacers
Just a pic request really, need to know how 20mm spacers look on the rear of a vRS.
Also are there any complications associated with fitting spacers?
Thankssssss
Standard 16" vrs wheels I assume?
If so altho i have no pictures 20mm look spot on - no issues.
Yeah standard 16's dude, are you running 20mm?
No but standard offset is 38 so with a 20mm adapter it will be et18 which will sit nicely in the arch :) there were some pictures on here but i cant remember the thread :(
What about if your running 17" Spiders? Is 20mm too much poke and do they catch on the arch?
I've got a set you can try mate
spiders are the same offset arent they? if so they shouldnt catch. :)
I'm on Eibach springs so doubt they will catch lol.
Ross I may take you up on the loan of the spacers for a trial fit fella.
Im running a 17x7 wheel, ET42 wheels with a 25mm spacer and 205 tyre and they sit in the arch perfectly. Id say i have around 3mm clearence
What wheels do you have on Mo?
Speedline ST2 wheels off an Imprezza
Iv fitted some H&R 20mm rear spacers and they do poke a little, I'm a bit unsure on them to be honest, I'm wondering if 15mm versions would be better, running spiders.
Edited by redcupraboy
