MDI Interface Not Working All the time
Hi.
When I connect my iPhone to the media interface with the MDI cable, sometimes its playing and responding form the stereo but there’s no sound. Disconnecting and reconnecting the phone seems to sort this. My MDI cable is spanking new so it not that. Is this just 'one of those things'?
Only thing I can think of is that the case for my phone stops the MDI cable form fully engaging, in that I can pull it out without having to squeeze the cable. If I use it without the case it clicks in and needs a squeeze to disconnect it.
Taking it out of its case is a pain.
BTW - I have GSM Bluetooth too - could that be interfering?
From what I have found on the MDI link, is to let the phone connect before you plug the phone to the MDI. I had the same problem but the later plug in works fine. Hope this helps.
Ade
must be i-phone specific maybe what para says above :) I use a 250 gig HD and have never had that problem..
Got a 32gb flash drive that's fine too. I can even stick new music on it and starts exactly where I left it as long as I don't delete the track
Typical from the iPhone!!! Lol works fine apart from that.
Harddisk sound interesnting. Is it a small one in enclosure that fits in the same space nect to the socket? I asume I need a different MDI connection lead t use a hard disk? A USB or something?
