Squeaky seat
Hi all
Had my fabia vrs for 2 weeks now
Noticed that the drivers seat seems to squeak sometimes when you move in it
It's a little bit worse now with coilovers fitted as its moving more...
Anyone else had this?
Maybe wd40 will sort it?
The one in my car does too (same seat base I believe).
Give it a wiggle. If you can see the rails moving then the bolts need tightening.
If the rails don't move but the seat base does then it is likely to be a joint under the seat. I had a look and it's a riveted joint so can't be tightened so just going to grease it and hope the noise goes away.
Phil
Thanks for the help mate
Will take a look tonight :) hope it's just a bolt
From what I understand it's the springs from the height adjustment system. I was about to take the seat out to fully oil them and then it just stopped squeaking. Not really sure what triggered it to stop.
