Columbus discs?
Is it correct that the columbus only has a single cd capacity? Just swapped over from the bolero and im a bit shocked!! Will be keeping tho as a way better unit , anyone for a bolero?
Yes that's correct.
Bolero was introduced after the Columbus and (I believe) the Columbus was always paired with the 6-disc changer.
Now that the Amundsen range is out, I doubt the Columbus will be around much longer.
Oh well can't win em all!!!
No need for a Changer with Columbus, as you can put all your music on the hard disc, or use an SD card. It doesn't come with the changer on a Superb elegance.
Good point!
Ignore my ramblings...
Why does the Bolero have a 6-disc changer and an SD slot then?
I got a six cd changer linked to a Columbus too, but never use it. Much better to work off SD card or hard disk.
Yes that's correct.
The Columbus is a better unit than the Amundsen unit.
Columbus is much better than the amundsen
VW have introduced the RNS315 (amundsen +) to a lot of their cars as it has DAB where the RNS510 (columbus) doesn't
Columbus is the Premium radio
