octavia strange engine proplem
i have a 1998 octavia a4 with 1.6 engine aee it makes me mad when i start the engine i hear a noise from the throttel and when i look the gate of the throttel is not seated and the car will not run and even i when i try to push the car to a slope and run it it runs very shaky and not smooth and the rpm goes to 2000 or 3000 i tried to clen it many times put it keep coming back sometimes the car stays ok for 7 to 10 days then it makes the same again and sometimes it happenes 2 or 3 times in the same day i wonder wht i should do the work shop reset the throttel to basic settings but it still coming back i wonder if it is the throttel or the fuel pump or the lampda sensor . may big problem is this engine is not popular in my countery so can any of u help me with this annoing problem thanks alot
have you cleaned out the throttle body first----also check all rubber pipes for splits/perrishing or blockage
