R32 front anti roll bar mounts
Are these different to the vrs?
I had my mate and dad help me fit hubs and bits sent from billy on here.... And somehow theyve binned the mounts for front anti roll bar and the bushes. The bushes i will have to replace but what about the mounts?
Yeah I believe the are bigger mounts to cope with the bigger bar mate
What.
Them bushes were new lol only on a few thousand lol. The metal brackets are the same mate just the bush inside is different. So long as its gor the ridge in the middle? The old bushes didnt have it hence the plastic sleeve but new ones did.
Hope that makes sence.
It was all attached lol just ready to unwrap n fitiirc.
not true buddy.
As Billy states the mounts are the same bracket and P/N whether VRS,TT,S3,R32, LCR etc
it is the bush the bracket clamps on that is different to accomadate the thicker ARB of the R32 being 23mm ones.
hope you find them bud as I said the bushes were superPRO ones and pritty much new lol.
1J0 411 336 D is the clamp
for the bushes just go on a superPRO site and get a bush that ends in -23
if your bracket has the like fin in middle of it going as if round the bar then its fine to use.
Believe me! I was screwing this morning when I couldn't find them! Especially considering I have had to order the loom for the ABS wheel speed sensor because my dad broke that being too heavy handed and lazy.
Its actually costing me more to get it sorted by myself (with help) than it is to take to a garage and get it all fitted.
I remember taking the box out with the hubs and all the mounts, and the box was later used for rubbish but they never took all the bits out beforehand clearly.....I will check the boot again tomorrow, as I was in a rush earlier. Fingers crossed I still have them! Gonna cost me £40 in parts to replace all that :/
Mate I cant remember if I put all the stuff in there? if the bushes n metal brackets wernt on the bar then yea it all went in. HOPE YOU GOT THE REAR BAR brackets out tho? they are over 120 notes iirc.
yeah, that was all cable-tied together because we were gonna fit it thinking it was a quick job....and yeah, gave up after bolting it to the struts and couldnt get the purchase for the brackets to go over the beam. I saw those and definitely still have them!
good good, Yea mate the brackets are a pain in the ass, took me 2 hr to put it on mine but once on mate its on to stay, brill setup imho. best off fitting it to beam first then on the struts.
Not a pain if you first bolt the brackets in with longer bolts as this helps compress the bracket and bush together, then just remove bolt and replace with correct size one.
he is on about the Neuspeed RARB mate, its a paing getting it wrapped round that bar and clamped on.
Ah that makes sense buddy, yep they are tight, I managed to get the hang of them too, by locating the bracket over top of beam and then pressing the front section of bar towards beam which then the bracket just clipped over nicely and then i tighten up
