Sat Nav Fabia VRS 06
Hi,
Is anyone selling a Skoda Sat nav system for a fabia and if so how much?
Also - Would one of these be easy to fit? I would of thought the hardest part would of been running the GPS cable?
Anyone?
Not selling one but pretty easy to fit,
Make sure you get the MFD bypass wiring loom that just goes in with the satnav
Even the gps aerial is pretty easy, run the wire from the unit into the passenger footwell just under the carpet, bring it round to the door should just slot behind the plastic trim then behind the door seal then just keep going up the door seal until you reach the headlining pull down the door seal at the top remove the grab handle slot the magnetic aerial until it grabs onto the roof then put back the bits you removed :) hope that helps!
If its a bit confusing let me know and i can take some pictures and put some arrows on them to make it easier to understand :) sometimes things make sense in my head but make no sense when i say them :giggle:
Thanks Adamweal.
I might take you up on that offer if I can find someone selling one :)
On that note...
Does anyone know what Model I should be searching for - I have a Fabia VRS 06 Plate.
pretty sure its the travelatlas DX cant remember if skoda call if different now! haha
