Adding the Bluetooth/MDI system to Octavia?
I can't see why BT can't be retrofitted to the Blackline. You'll just need to make sure you get the right cables for the HU you have in place and the right BT module to give you the functionality you want.
Streaming will be possible, depending upon the BT module you choose and BT type your phone supports, but the HU will only allow you to play a random selection from the phone. If you want to choose the music you listen to, you will need to select it from the phone first and 'push' it to the HU.
As for the Blackline having MFSW as standard, I don't know. Sorry.
Seems the Blackline will come with BT as the satnav is the plus version which has DAB based on the user manual it comes with BT for streaming and Phone.
Seems also that the Blackline will come with maxidot as the satnav needs it.
Here is the user manual link i have included both the standard and plus versions
PLUS with DAB https://mediaportal.skoda-auto.com/resource/documentation/manuals/en/Fabia/11-2011/Navigation/A05_Fabia_Amundsen_NavigationSystem.pdf
Standard http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&sqi=2&ved=0CD4QFjAC&url=http%3A%2F%2Fwww.octinfo.com%2Fdownload.php%3Ffile%3Dmanual%2Foctavia2fl%2F06_2009-10_2009%2FA5FL_Octavia_Amundsen_NavigationSystem.pdf&ei=ldBVUMSWMsWt0QW09YCYAw&usg=AFQjCNFLs_4zJG2NVUIj1sYnIn4wX78Xew
PLUS with DAB https://mediaportal....ationSystem.pdf
Standard http://www.google.co...j1sYnIn4wX78Xew
Are you sure it will be the + version?
I was just in my local Dealer and he said it was without BT for the Blackline that i was askin about.
If i re read your post i see that the standard one doesen't have DAB therefore it must be the + ?
if i compare the two user manuals then the difference is DAB on the plus and BT is detailed with no mention that the pre GSM installation has to be present like it states in the standard manual.
I have to wait to see what the dealer finds out tomorrow.
