Strange low fuel scenario
Hi,
Just a new one on me, went to go and fill up this morning with diesel as the range was showing 45 miles as the warning light had come on last night. It then It beeped loads when I started it, the light went off, the gauge goes up and the range goes to 115 miles.
Nothing in the manual, any ideas?
Matt
Range ( AFAIK) is calculated on last so many miles. That said, I find that anything in the reserve range is not accurate.
Its calculated on your average MPG and fuel left.
For example
Drive hard and average 25mpg - means you may have 50 miles left and putting the fuel light on
Drive economically and get 50mpg and have 100 miles left
The light comes on at 60 miles on my car.
Adam
Quite likely the light came on when cornering. Once on it stays on until it resets itself which it does after being turned off for a few hours. Overnight it "lost it's memory" so,in the morning when you drove slowly, it would start using the fuel calculation just for the morning. based on the measured amount of fuel in the level tank.
On the other hand you might have local pixies who top up your tank at night - if so, can I park outside your house please? :sun: :sun: :sun:
My light comes on around 30-40. But mines a facelift Ibiza, still the pd130 though.
I find the reserve drops down quite quickly too.
Well when I started it was in the red, loads of beeps and it went up to quarter of a tank, all whilst stationary!
I thought it may e some strange 'reserve' tank dropping its load in there.
Must be pixies!
