Fabia VRS Radio Change
Hi Having had my Fabia for nearly 3 weeks now I want to fit my Sony H/U, Mini Disc changer, Sub and amp. Talking to the garage and a car audio shop this can be a problem as if wired wrong it can blow the H/U. Does any one know why this would happen and if it has happened to anyone?
Has anyone had there after market H/U fitted by the dealer and if so what sort of cost was it?
Thanks.
:confused: :confused:
Fitting a head unit is usually very very simple! If I can do it you probably can.
I've never heard of a h/u blowing because of bad wiring, unless you get it very wrong as in the live cable going from the battery straight to the head unit.
Don't bother with a mini disk changer, get a Sony h/u that can read MP3 and get a 6CD changer. I can fit about 120 songs per cd, so times that by 6 and you get a hell of a lot of music.
If you can stretch to one get an Alpine h/u, I have actually got a JVC (I got a nice deal on it) and it is very very good.
Don't forget to change the speakers that are in the car!
Hope this helps a little!
I've never heard of a h/u blowing because of bad wiring' date=' unless you get it very wrong as in the live cable going from the battery straight to the head unit.
Hope this helps a little![/quote']
Already own the H/U and mini disc changer, it allows me to do long play mini discs (approx 4/5 hours on each disc). Have fitted radios in to many different cars, but never been told that it coiuld blow, thanks.
I was told by car sound that it is easy to blow the head unit if wired wrong on the fabia, i am sure he was trying to put me off doing it myself, i can buy the head unit Dab ariel and blanking plate for
