Nearside mirror drop on reverse
Is this std on the Yeti or is it only available on upgrade?
Looked in the mfd and theres the mirror option, says both, or independent. Can't remember how to get it to work. Any help appreciated.
That setting just alters the way adjusting the mirrors works. Usually to get the reverse dip working all you do is leave the mirror adjuster in the passenger adjust position.
To have the mirror dip function your car must have electric seats with memory function, as the ECU stores the mirror positions to know where to return to when you drive off. If you only have manual seat adjustment then you will not be able to get the reverse dip.
Ah ok, don't have that on this car.
Had to buy this one myself so sadly no full spec ;-)
