Anyone good with lamin x Cheshire area?
Hi
Anyone fancy lending a hand one evening or weekend doing my front lights?
I had a stab with the fly eye stuff at the weekend but it's a bit bodged so wanted to re do it
I did mine a few weeks ago mate. Put a mist of window cleaner on them then you can move the vinyl around. Once it's dried it's stuck on :)
Yeah that's what I did... Lightly sprayed the light with water then apply the lamin-x. Makes it much easier to pull off/adjust as required.
I also used an old paper.... Cut to size and use as a template to reduce waste/f'ing & blinding!
I also wrapped mine around the edges a bit as you can still see the edges of the light at some angles :)
