Coding Skoda Superb LED taillights in VCDS Byte 18
I've just bought a LED taillights and I've programmed Byte 18 to with the following HEX. This simply solves the error code, but on the other hand I lost the functionality of front Daylight Running Lights.
So, I need the HEX code for Laurin Klement Version of the Skoda Superb which includes Seperate Front DRL's and LED taillights. Do you know anything close to this specs. Any setups with front conventional DRL's with LED taillight configuration. Help is appreciated.
74 Skoda Superb (SK461) Halogen / Xenon China China without DRL SL with BL-function LED SBBR 75 Skoda Superb (SK461) Halogen / Xenon China China without DRL / TFL-ABL SL without BL-function LED SBBR
Edited by rumiexile
any updates?
  • 4 weeks later...
Here is my detailed Autoscan. By the way is it possible to adjust the brightness of LED taillights?
Chassis Type: 7N0
Scan: 01 03 08 09 10 15 16 17 19 25 36 42 44 46 52 55 56 62 72 77
VIN: TMBAA63T8B9011028
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CAX)	   Labels: 03C-906-016-CAX.clb
  Part No SW: 03C 906 016 AL    HW: 03C 906 016 C
  Component: MED17.5.5	   G   5294
  Revision: LCH09---    Serial number:
  Coding: 0000072
  Shop #: WSC 33361 790 00082
  VCID: 69DDB99739E9
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)	   Labels: 1K0-907-379-60EC1F.clb
  Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
  Component: ESP MK60EC1   H30 0105
  Revision: 00H30001
  Coding: 843D6016092300FB210B06E690210040350000
  VCID: 84030823BE8B
Address 08: Auto HVAC (J255)	   Labels: 5K0-907-044.clb
  Part No SW: 3T0 907 044 AR    HW: 3T0 907 044 AR
  Component: Climatronic   H15 0401
  Revision: 00005001
  Coding: 0000000002
  ASAM Dataset: EV_Climatronic A01006
  ROD: EV_Climatronic_SK46.rod
  VCID: 820F0E3BA49F
Address 09: Cent. Elect. (J519)	   Labels: 1K0-937-08x-09.clb
  Part No SW: 1K0 937 087 P    HW: 1K0 937 087 P
  Component: BCM PQ35  H+  104 0615
  Revision: 00104 AE
  Coding: 46990AB8E85BF1C040080080310089E4467031FD732089605C0040000040
  VCID: 3E773ACB10E7
  Part No: 3T1 955 119
  Component: Wischer 17061  22  0602
  Coding: 00D7B7
  Part No: 1K0 955 559 AH
  Component: RLS 160610 05  54  0403
  Coding: 0730ED
  Part No: 1K8 951 171
  Component: DWA-Sensor 00  001 0104
  Part No: 1K0 951 605 C
  Component: LIN BACKUP HO  H05 1501
6 Faults Found:
00984 - Left Tail Light (M4)
	    010 - Open or Short to Plus - Intermittent
		 Freeze Frame:
			    Fault Status: 00101010
			    Fault Priority: 2
			    Fault Frequency: 62
			    Reset counter: 48
			    Mileage: 52090 km
			    Time Indication: 0
			    Date: 2025.14.26
			    Time: 23:03:40
		 Freeze Frame:
				    Term 15 On
			    Voltage: 11.85 V
				    ON
				    ON
				    Term 50 Off
				    OFF
				    OFF
00985 - Right Tail Light (M2)
		 Freeze Frame:
			    Fault Priority: 2
			    Fault Frequency: 62
			    Reset counter: 48
			    Mileage: 52090 km
			    Time Indication: 0
			    Date: 2025.14.26
			    Time: 23:03:40
		 Freeze Frame:
				    Term 15 On
			    Voltage: 11.85 V
				    ON
				    ON
				    Term 50 Off
				    OFF
				    OFF
00987 - Lamp for Brake Light; Left (M9)
		 Freeze Frame:
			    Fault Status: 01101010
			    Fault Priority: 1
			    Fault Frequency: 96
			    Reset counter: 20
			    Mileage: 52090 km
			    Time Indication: 0
			    Date: 2025.14.26
			    Time: 23:03:40
		 Freeze Frame:
				    Term 15 On
			    Voltage: 11.85 V
				    ON
				    ON
				    Term 50 Off
				    OFF
				    OFF
00988 - Lamp for Brake Light; Right (M10)
		 Freeze Frame:
			    Fault Priority: 1
			    Fault Frequency: 95
			    Reset counter: 20
			    Mileage: 52090 km
			    Time Indication: 0
			    Date: 2025.14.26
			    Time: 23:03:40
		 Freeze Frame:
				    Term 15 On
			    Voltage: 11.85 V
				    ON
				    ON
				    Term 50 Off
				    OFF
				    OFF
	    014 - Defective - Intermittent
		 Freeze Frame:
			    Fault Status: 00101110
			    Fault Priority: 2
			    Fault Frequency: 24
			    Reset counter: 60
			    Mileage: 53335 km
			    Time Indication: 0
			    Date: 2026.14.04
			    Time: 20:51:07
		 Freeze Frame:
				    Term 15 On
			    Voltage: 12.25 V
				    ON
				    ON
				    Term 50 Off
				    OFF
				    OFF
		 Freeze Frame:
			    Fault Priority: 2
			    Fault Frequency: 24
			    Reset counter: 60
			    Mileage: 53335 km
			    Time Indication: 0
			    Date: 2026.14.04
			    Time: 20:51:07
		 Freeze Frame:
				    Term 15 On
			    Voltage: 12.25 V
				    ON
				    ON
				    Term 50 Off
				    OFF
				    OFF
Address 10: Park/Steer Assist (J791)	   Labels: 1T0-919-475.clb
  Part No SW: 3T0 919 475 A    HW: 3T0 919 475
  Component: PARKHILFE PLA H07 0003
  Revision: --------    Serial number: 78331014801014
  Coding: 100004
  VCID: 3B7133DF03F5
Address 15: Airbags	    Labels: 5N0-959-655.lbl
  Part No SW: 3T0 959 655 B    HW: 3T0 959 655 B
  Component: J234__LCK VW10 HI   1916
  Revision: 19014000    Serial number: 003GRPBTZXW$
  Coding: 0017227
  Shop #: WSC 33361 790 00999
  VCID: 408B44336A13
Address 16: Steering wheel (J527)	   Labels: 5K0-953-569.clb
  Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
  Component: LENKS.MODUL   009 0136
  Revision: FF010036    Serial number: 20100623100330
  Coding: 008A140000
  Shop #: WSC 01188 423 92378
  ASAM Dataset: EV_SMLSNGVOLWS A01004
  ROD: EV_SMLSNGVOLWS_SK46.rod
  VCID: 76E7E2EB7857
  MFL:
  Part No SW: 3T0 959 537	 HW: 3T0 959 537
  Component: E221__MFL-URO  H07 0012
  Coding: 800000
Address 17: Instruments (J285)	   Labels: 5K0-920-xxx-17.clb
  Part No SW: 3T1 920 841 G    HW: 3T1 920 841 G
  Component: KOMBI		 H04 0406
  Serial number: 00000000000000
  Coding: 110F01
  ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
  ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
  VCID: 37792FEF3FDD
Address 19: CAN Gateway	    Labels: 7N0-907-530-V1.clb
  Part No SW: 7N0 907 530	 HW: 1K0 907 951
  Component: J533  Gateway   H27 0602
  Revision:   H27	   Serial number: 200610F1000907
  Coding: E9A1FF0600060200003302
  VCID: EDD54D878D01
Address 25: Immobilizer (J334)	   Labels: 5K0-920-xxx-25.clb
  Part No SW: 5K0 953 234	 HW: 5K0 953 234
  Component: IMMO		  H04 0406
  Coding: 000000
  Shop #: WSC 00000 000 00000
  ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
  ROD: EV_Immo_UDS_VDD_RM09_SK46.rod
  VCID: EADF469BBCEF
Address 36: Seat Mem. Drvr	    Labels: 3C0-959-760.lbl
  Part No SW: 3C8 959 760	 HW: 3C8 959 760
  Component: J810			    0801
  Revision: 00002000    Serial number: 00000000000000
  Coding: 0000003
  VCID: F2EF5EFB943F
Address 42: Door Elect, Driver (J386)	   Labels: 8X0-959-793.clb
  Part No SW: 8X0 959 793 C    HW: 8X0 959 793 C
  Component: TSG FA	    H09 0409
  Revision: --------    Serial number: --------------
  Coding: 011D0220DE00001000
  VCID: 4D956D07AD41
Address 44: Steering Assist	    Labels: 1Kx-909-14x-44.clb
  Part No: 1K0 909 144 J
  Component: EPS_ZFLS Kl. 193    3001
  Revision: 00H17000
  VCID: 316D11F7D1B9
Address 52: Door Elect, Pass. (J387)	   Labels: 8X0-959-792.clb
  Part No SW: 8X0 959 792 C    HW: 8X0 959 792 C
  Component: TSG BF	    H09 0409
  VCID: 4C936003565B
Address 55: Xenon Range	    Labels: 5M0-907-357-V2.lbl
  Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
  Component: AFS-Steuergeraet    0142
  Revision: 00H04000    Serial number:
  Coding: 1376839
  VCID: 346318E32EAB
  Part No: 7L6 941 329 B
  Component: AFS-Lst.-Modul l    0004
  Coding: 00000021
  Component: AFS-Lst.-Modul r    0004
  Coding: 00000021
Address 56: Radio (J503)	   Labels: 5M0-035-1xx-56.clb
  Part No SW: 3T0 035 156 C    HW: 3T0 035 156 C
  Component: BOLERO	    013 0029
  Revision: -----27S    Serial number: SKZ4Z3K1104238
  Coding: 0D0004000004
  VCID: 2E570A8BC087
Address 62: Door, Rear Left (J388)	   Labels: None
  Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
  Component: TSG HL	    H06 0409
  Coding: 010C00200000001000
  VCID: 4E976A0BA047
Address 72: Door, Rear Right (J389)	   Labels: None
  Component: TSG HR	    H06 0409
  VCID: 4E976A0BA047
Address 77: Telephone (J412)	   Labels: 3C8-035-730-A.clb
  Part No SW: 5N0 035 730 D    HW: 5N0 035 730 D
  Component: Telefon	   009 0511
  Revision: --------    Serial number: 35909603119888
  Coding: 020001000000000000000000
  Shop #: WSC 12345 123 12345
  ASAM Dataset: EV_UHVPremi A01005
  ROD: EV_UHVPremi_SK46.rod
  VCID: 295DF997F969
3 Faults Found:
9458451 - Cellular Antenna:
	  B1053 13 [009] - Open Circuit
		 Freeze Frame:
			    Fault Status: 00000001
			    Fault Priority: 4
			    Fault Frequency: 1
			    Reset counter: 220
			    Mileage: 51624 km
			    Date: 2025.14.18
			    Time: 21:42:45
9457939 - Telephone baseplate
	  B1051 13 [024] - Open Circuit
		 Freeze Frame:
			    Fault Priority: 4
			    Fault Frequency: 1
			    Reset counter: 220
			    Mileage: 51624 km
			    Date: 2025.14.18
			    Time: 21:42:45
9458193 - Control Module for Cellular Telephone
	  B1052 14 [024] - Short to Ground
		 Freeze Frame:
			    Fault Priority: 4
			    Fault Frequency: 1
			    Reset counter: 220
			    Mileage: 51624 km
			    Date: 2025.14.18
			    Time: 21:42:45
  • 5 months later...
Hi rumiexile
Did you find a good answer to your problem?
@+Pat
  • 2 months later...
I'm guessing no one has yet discovered the byte 18 coding?
