Octavia II FL LED from China version
Hello, I have European Skoda Octavia II MY 2012. I buy LED tail lights from VW Shanghai and I installed these tail lights. All works perfect. Only is problem with voltage, light is too strong.
I compared coding between my Octavia and Superb II L&K (european) and I find many differences. I tried lot of options and I successfully change voltage in side and top in lights, not in bottom.
Is here any person which can copy central electric coding (with VAS) from Chinese Octavia? I think, cabling is the same from scheme which i have. Problem is only in coding.
Thanks.
Edited by lubor
Thanks.
I saw this tail lights in china and i like it too much, i was thinking of buying it but i wasn't sure if the wiring is the same,
now you said wiring is the same , hope u got the correct setting to make it work good.
Socket is different! You must remake this socket and then work fine. But the biggest problem is with luminous intensity. I think, this is only with coding. We must have to coding from Chinese Octavia...
Edited by lubor
