Standard rideheigt 1.9 tdi combi
Does anyone know the standard rideheight of the 1.9 tdi combi?
Have just installed Weitec ultra gt´s 25mm drop and it seems to have dropped more than the 25mm, but i didnt measure the standard rideheight before installing.
Which wheel and tyre combo, and where do you want measuring between? I can get you heights at the arches for an Elegance running 205/55R16s.
Im running the same tyres as you are my mesaurements are:
Front:
- approx. 40 mm between top of tire to arch
- 355 mm from arch to center of whhel
- 650 mm from arch to ground
Rear:
- approx. 30 mm between top of tire to arch
- 345 mm from arch to center of whhel
- 640 mm from arch to ground
it sems like, according to "AndrewTait" link that i have gone down 35 mm rear and 35-40 in the front. So more like a 35mm lowering set than 25
But it would be awsome if you could measure from center of wheel to arch :)
Rim centre to arch in mm:-
Front 380
Rear 370
Which surprised me slightly, because the profile is nose-down.
Front 380
Rear 370
Thank you :)
Seems like it is a 25mm drop then afterall
