Maf Wiring Diagram Needed
Currently i'am trying to fit a tdi dump valve kit and i'am looking for a maf wiring diagram as i need a feed from the 5v throttle sensor and as i've been finding out through the day the maf has this so if anyone can inform me to which wire this would be on the maf or an easier way of getting 5v throttle sensor feed, i would be very greatfull
Why not just stick a multimeter on the pins in the MAF plug and work it out?
was thinking on doing that but wasn't 100% on the idea
I just googled it - first hit gives this:
http://www.ohiodiagn...diagnostics.pdf
3 - earth
4 - 5v from ECU
How much power does your dump value kit draw, or is it only using the +5vdc as a trigger?
5v sensor as the trigger
thanks mate i did try and never found anything might have been the way i worded my search thanks again
Edited by sesachc
I think I googled for "bosch diesel vag MAF" or something like that.... Good luck with getting it fitted though.
Cheers mate
