EGR Delete Kit
The vRS has a BLT engine. I have found an Allard EGR delete kit on eBay.
Apparently, it is possible that a warning light will appear on the dash when it is fitted.
Has anyone got one fitted and did the warning light appear? If so how did ypu get it turned off?
SN
Yes you will get a light flagged up, make sure you buy the correct delete kit, not the long one for an ASZ. It will be shorter with bolt holes at either end as the EGR sits between the ASV(anti shudder valve) and the inlet manifold.
It can be mapped out by most reputable mappers :)
