adapter kit for new radio
hello all
just a quick question, ive bought myself a new sony double din for my 2005 fabia vrs.
just wondering what adapter kit i need to avoid wire cutting!
Welcome!
Shouldn't need any from memory, it should just fit (or at least, the Sony and Pioneer I put in worked fine).
There should be a red and yellow wire with bullet connectors in - this might need to be swapped around so it keeps the settings when the ignition is removed (so red goes to yellow and yellow to red). Just tune into a station and turn it off before putting it in properly. If it keeps the station then :thumbup: if not, swap the cables. :)
Edited by TriggerFish
You'll need an aerial booster and a facia piece from the main dealer to make up the piece between radio and switches above. As above no wiring adapters needed just swop red and yellow
