No power- misfiring - clouds of white, & grey smoke
Hi
I have a 2006 superb 1.9tdi 130bhp AWX that will not rev above 2000 rpm. When at 2000rpm its misfiring and producing clouds of white and
grey smoke.When idling its fine. There was one error code on the Vag Com - 19464 - camshaft position sensor (G40) signal out of range.The error code never appeared again after I cleared it.
This problem only appeared after I push started the car. I travelled about 20 miles first thing in the morning to go shopping and I left the lights on while parked .When I returned there was not enough in the battery to start the car so a couple of people helped me push start the car and then this happened. I dont know if its a total coincidence.Its like the turbo has given up but its the serious misfire that causing me the issue.
Another issue may be the flywheel. The engine was vibrating more that normal and sometime tricky to get into first gear prior to this problem. I think that the DMF was on the way out.
I am looking for some ideas before I start replacing the turbo/DMF/Injector wiring loom.
Edited by jimmca
