Depo projector headlight
Just got one this morning and i'am rather impressed but thing is does anyone know where i can get a headlight motor to fit it as my standard ones don't
havnt got a clue about the motors but wondering if youve got it wired up? im sat here looking at a mess of wires wondering what goes where?
Ive done a DIY in the technical guides section, convertion OEM halogens to DEPO xenons :rock: , havent found a soloution to the adjusters yet, ive just bolted a plate with a tapped hole across the motor mounting holes and used a long M6 bolt with the head ground down so it fits in the ball socket the OEM motor uses. I then cut a slot in the other end(thread end) Use a screwdriver to turn the bolt and they adjust nicely.
If you don't mind me asking where did you get these from?
