Diagnostic Interface Cable - Help?
Hi,
Sorry this has properly been asked many times but I can't seem to find the answer. Can some confirm if this is the right cable for a 2006 Fabia VRS tdi
http://www.gendan.co.uk/product_VAGUSB.html
My power steering has failed and unfortunately replacing the battery didn't fix it so I need a cheap option to just see what fault codes there are. Fingers crossed it's not the pump!!
Kevin
where in Soton are you? I've got vcds lite and a cable, happy to help if I can :yes:
Hi,
That cable will do fault codes just fine on 2006 Fabia, can highly recomend Gendan
I have just bought that cable and they checked that my octy was before 2004 as they said it would not work otherwise.?
Hi,
Some cables arn't compatible with can bus in the newer models
Sent from my Galaxy S3, not a Crapple!
