Phone bluetooth problem
My iPhone is linked to the Yetis bluetooth system and worked well until last night.
I can access the phone on the MFD using the steering wheel buttons on the left hand side but once I get onto the phone screen I cannot scroll up or down using the thumbwheel.
I can select by pressing the thumbwheel but cannot scroll. [through phone book etc]
The scrolling works on all the other MFD menus.
I tried taking out the key and restarting the car.
Is there any way of resetting the computer somehow?
see page 19 of the manual
Note
? If warning messages are shown in the information display, these messages can be confirmed with the button » Fig. 7 on the windshield wiper lever in order to call up the main menu.
? If the information display is not activated at that moment, the menu always
shifts to one of the higher levels after 10 seconds. ?
Time
The time, time format (12 or 24 hour indicator) and the changeover between sum- mer/winter time can be set here.
Winter tyres
This where the speed at which a warning signal should sound can be set. This function is, for example, used for winter tyres with which the permissible maxi- mum speed is lower than the maximum speed of the vehicle.
When exceeding the speed, the following is shown on the information display:
Winter tyres: max. speed ... km/h Measures
The units for the temperature, consumption and distance driven can be set here.
Second speed
The display of the second speed in mph or in km/h can be switched on here1).
Service
Here you can have the remaining kilometres and days until the next service inter- val displayed, and reset the Service Interval Display.
Factory Setting
After selecting the menu Factory setting the factory setting of the information display is restored.
Door, luggage compartment door and bonnet ajar warning
a? First read and observe the introductory information and safety warn- ings on page 18.
The door, luggage compartment and bonnet ajar warning lights up if at least one door, the luggage compartment or bonnet are not closed. The symbol indicates which door is still open or whether the luggage compartment door or bonnet is not closed.
The symbol goes out as soon as the doors, luggage compartment door and bon- net are completely closed.
B
Settings
You can change certain settings by means of the information display. The current setting is shown on the information display in the respective menu at the top be- low the line.
The following information can be selected (depending on the equipment installed on the vehicle):
› Language
› MFD Data
› Time
› Winter tyres
› Units
› Alternative speed displayed › Service
› Factory Setting
› Back
After selecting the menu point Back you will reach one level higher in the menu.
Language
This is where the language in which the warning and information texts should be displayed can be set.
Displays of the MFA
This is where certain displays of the multi-functional indicator can be switched on or off.
A warning signal sounds if the car is driven at a speed of more than 6 km/hour with the door, luggage compartment door or bonnet open.
1) Valid for countries where the values are indicated in British measuring units.
Instruments and warning lights 19
Regards
Mike
Thanks Mike...will try the reset :blush:
