Help
Hi all
Got a few issues and wondering if anyone else has had the problem
The car smells really bad of petrol and the fuel comsumption has dropped
The turbo also doesn't seem to be working right sometimes I can hear and feel it kicking in and other times I can't and the car is slUggish
Then other times when I put my foot times the turbo comes in the shuts off
I'm sure it's a split pipe somewhere but any ideas where
Cheers all
your just gonna have to eyeball all the boost pipe mate and try and see if there is a split, or bad join. Also check for fuel leaks of course, given that there is a smell of petrol.
Cheers mate thought that might be the case
worth getting the codes read aswell if you can, see what the brain can tell you
where in scotland are you?
Edited by Lofty79
Inverness mate couple of hours north of ya
A mate plugged it in but no faults not sure what he used though
ah never mind then, id have once overed it for ya and scanned it with vag-com.
Maybe your mate scanned it with a potatoe :giggle:
Hope you get it sorted, if ever your down this way ill happily run some tests
I'm driving down to Yorkshire on the 12 how far of the a9 are ya
about 11.5 miles, you come off at dunkeld, and follow the road through to blairgowrie, about 20 mins off the a9.
Let me know if ya wanna pop by
Sound mate cheers will do
Sounds like you have similar issues to me however my turbo picks up and holds boost however gut feelings telling me its the maf sensor but I need to re install my vag com to see what that says ... Hope you get it sorted buddy
So do I mate does yours cut out sometimes to
Of you cure yours let me know what it was mate
I cant believe there are no fault codes? Sounds like its running like a pig.
Get a VAG COM cable if you have a laptop and go from there.
