Random bulbs - Cheers to the ones with powers :D
Guys..... Quick bulb check ;)
What bulbs are
Interior light.... Main and outers
And mwhat are number plate lights
And also do i need canbus jimmys
Edited by Lloyd55vrs
Oooops so this is where i clicked submit lol
Feck
Can those with the powers put it in octy 1
:( my bad
no canibus needed. 501 map lights, festoon middle :)
What size feston Gee matey :)
I found a choice of lengths of them
Specifically a 43mm Festoon for the middle. C5W is the class for Festoon, but doesn't specify the size.
Door lights are the shorter 38mm Festoon.
Map lights and number plate lights are 501 bulbs.
Might have a spare 43mm and a 38mm, both Philips White LED bulbs, if that's what you're after. And I think I might have a pair of the 501 LED bulbs spare too. All in 4KHz. (White white, as opposed to Blue white)
FYI, the current Philips 43mm have only the one LED segment on them, whereas the smaller ones have multiple. They both appear to be the same brightness though.
Just in case you do want these, I'll let them go for £10 a pack. (Festoons come individually and the 501's come in pairs). All are completely unused (although one of the festoons may have part of the packaging removed, whilst I discovered I had the WRONG BULBS! GRRRRRR!)
Cheers bud :)
For some reason i fancy red inside lol
I blame the alteas ambient weirdy red lighting :D
I hunted led bulbs on ebay......... SILLY :D
Hahahaha, weirdo. Dude you've GOT to fit those painted parts, if that's the case. Don't be a girl...
he is being a girl....
come on lloyd, grab those cojones!!!
But it may
1 break :( knowing my luch a sneaky bit of grit will drop into whatevers under it :D i bekeve it to be cams or valves :( i have know idea haha
2 i need rocker gaskets which is like 30-40
And inlet gasket and throttle body gasket
3 it will break something else :(
4 i now want a michi catch can .... Which
Are you ready luca???
I was planning to fit myself lmao
I have marks guide saved :D " i think its mark "
( im at my briskie name limit hehe no room lef in the voide between my lug holes )
on a serious note then lloyd, sell the bits you have, they are only bling, and your car is nice enough without!
get the SMichi catch can setup, fit that instead, use the money you get from selling the other bits to go towards it.
Its a way more useful part to add to your engine, that actually does something to help it, rather than just look good.
simples.
You just like the thought if me fitting something dont you lol
I dunno what id get for them
I did contact wicked coatings about carbon dipping my inlet and rocker ;)
It gets up around 300 notes eeeeek
Agreed. I must admit, even if I did fit them, I'd polish the living $h!t out of mine, lacquer them, and end up re-fitting them.
