URGENT! - passenger side leak
Hi guys. Some time ago I dicovered a swimming pool at the back. So first thing I did was clean drainage where the pollen filter is, it did change thing a bit, but not much. I took glovebox off to see where it comes in, and there is a hole (1st pic) where water is entering, and there is a hole next to the pollen filter (2nd pic), they are both connected, as water is entering there, i assume i should close that hole?
I'd imagine there should be a grommet, iirc people run power cables for amps through there.
yup am certain there should get a grommit in that, use some sealant too to be sure, think its the bonnet release cable hole for lhd vehicles.
thanks. Found a scrap yard who has mk1 facelift for breaking. Mine isn't facelift, the plastic that comes under the windscreen should be the same, shouldn't it?
should be, but can't promise, all you need is a bung though?
go to halfords and buy a pack, they do a range in there in a multipack, one should fit.
