fuel problem
This is a bit of a pain
my vrs 1.8t 2001 octavia when the car has under 1/4 of tank of petrol in it it will start and run but will stall when your driving along and when you try to restart it will not start just turns over like no fuel if you bump it will take 100m or more before it starts then it will be ok for 1 mile then it stall again.
today it run fine up to 1/4 tank then just stalled then over the next 3 miles it stalled out 6 times
i put £10 of petrol in it (147.9l)i just had the fuel pump out to checked the tank and there is about 4in of fuel in the tank no water or dirt in the bottom
fuel pump is clean
looks like a gfs or euro car pump as no numbers on the unit
changed plugs coils a fuel filter maf
drive fine till it gets to the 1/4 on guage then it starts playing up again if it stalls it will not start for the same amount of time each time
turn it off and back on when driving will not start then will just restart
stop and turn it over will not start
wait 4-8 seconds will start first time drive 500m or more then cuts out
i think its a relay getting no codes when it stalls
pump was changed because dealer had the car do this to them 2 months ago then been sat on forecourt for sale
i always though it was down on power
can you put the fuel lines on the wrong way on the pump?.had it before on a scirocco go up hill when the tank was low would cut out
runs fine if you dont go under 1/4 of a tank ive done over 3k of driving in it and no stalling when over 1/4 tank
are you sure the indicator is correct? when looks 1/4 tank ,you must have like 17l of petrol.
You must be sure that the gauge indicates correct first of all
are the fuel pumps the in all the 20vt cars ie golf a3 etc
going to try getting a 2secondhand one from the scrappy
to see if the new pump is bad one
Hate to say this but drop the tank and either clean it out properly or replace it sounds like something in the tank.
