Milltek exhaust fitting
Will be fitting the full milltek exhaust system with sportcat to my VRS midweek. After having a quick look under the car it seems like the standard exhaust is in one piece will it have to be chopped to remove it?
Yes that is correct. If you chop it in a sensible place (on the straight bit by the tank) it can be rejoined by a sleeve (VAG do this if you replace a silencer).
Pretty stright forward to fit once the old one is off though, good luck.
Thanks mate
No problems :)
