MFSW
Hello Folks
Just wanted to know that has anyone retrofitted MFSW in a FL??? The pre FL's used to have steering module under the steering wheel shaft inside cover next to the ignition switch. It is missing in my car(2011 FL). Does anyone knows where it is located???
Regards
Alam
It is part of the slip ring
My new Vrs should be here soon, I have the new wheel and new controller waiting for the car.
Pics will follow once I have done the job
So it means I have to buy one if it is missing in my car? I have only slip ring and I have checked through VCDS the steering wheel module and there I could see unticked options for MFSW, cruise control, DSG, Steering angle, etc. Do I need to buy anything else other than MFSW and airbag connecting cable?
Regards
Alam
It might help if you post up the part of the scan for the steering wheel. Here is the steering controller on a Vrs that I took for a test drive
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440LG8000FQ
Coding: 5080140000
Shop #: WSC 73430 790 00098
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_SK35.rod
VCID: 70E5F7BFAB40F398D15
No fault code found.
Part Number 5K0-953-549 Control Module Part Number Variant Notes 5K0-953-549 Lowline - 5K0-953-549-A Midline #1 5K0-953-549-B Highline - 5K0-953-549-C Midline - 5K0-953-549-D Highline #1
from the Ross-Tech wiki site we can see that the controller is a Midline version. So doesn't support MFSW
If the option is there for mfsw then you should try it, if it saves money.
I have a MFSW fitted to a non DSG FL Octy vRS, the link is extremely useful, i will howwver summarise for you:-
You will need:-
  • Access to a copy of VAGCOM
  • The MFSW, plus the small additional mini wiring loom ( i bought mine from Skodateille in the czech republic it was cheaper than UK even with postage).
  • Check that the steering wheel controller is a ' Highline ' version, you can get the current number from a VAGCOM reading & check out the link for the correct version you will need, You will probably have to buy a new one, I got mine from AVS, the parts man was VERY helpful & mine was slightly cheaper than from a dealer even tho AVS source from SUK.
Once you have all the parts then its just a case of :-
  • Carefully removing airbag & steering wheel,
  • Swap out steering wheel controller unit ( if needed)
  • Plug in the additional mini wiring loom into the new controller & feed through into new wheel & plug in
  • Refit new wheel
  • Re attach airbag
The awkward bit is to code in the new wheel, this is where Gizmo68 & VRSPhil have worked out the new code that can be input to ensure ALL the buttons on the wheel work & that the MFD buttons are disconnected from the stalk & transferred to the wheel. However you do not say if you have DSG as there will be a slight difference if you do have DSG
I can say that they all now work brilliantly & was worth every penny spent, with no fault codes remaining on the ECU :rock: :rock:
Eddie - recheck the controller on your car when it arrives to verify which part has been installed.
Also when i was speaking to AVS, to buy mine, their copy of ETKA only had midline & highline available to buy, & most of the older letters at the end of the part number were not available.( only S & T available)
I have all the parts, just hope my car has a controller ending 549 as that is what I have bought the Highend 549B and stalk without the rocker on the wiper stalk
new Mfsw looks ace.
just hope that the controller is not a 569
Hello Folks
Here is my steering part which I have scanned.
Part No SW: 1K5 953 521 AE HW: 5K0 953 569
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101205100869
Coding: 4080040000
Shop #: WSC 33361 790 00999
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS_SK35.rod
VCID: 70EBD4F31A33
I hope that some one can help me in finding what all parts I need or what is needed to be replaced.
Regards
Alam
Alam
When you check the codes in the link & match the letter suffix with 'Highline' column, be aware that when you speak to either AVS or Skoda parts that part numbers ending A - E may not still be available, as I could only get an H due to previous versions no longer being available.
Hello folks
I was able to arrange a brand new suitable control mudule 5K0 953 569 A from the VW dealership. I got it just to try out first, if it does work then only I have to pay for it. I coded the module exactly the way my previous module was coded, but it didn't go well with the car. The horn stopped working though the horn was coded to run, and the module gave lots of unknown errors including some "ROD". The MFSW which I arranged just to try out worked, ignition worked, wiper & indicator stalks worked, airbags worked, but the horn was not working at all. Then the dealer gave me another module 5K0 953 569 B to try out, I faced the same issue again. The car is running well now on its old module with everything working, Any ideas what could be wrong???
Regards
Alam
It needs coding to work, you also need to make sure the mfsw airbag loom is connected properly
But has anybody installed MFSW in FL???
Regards
Alam
Yes lfc958's is a FL, it's all down to your coding.
Is yours a manual or DSG?
On Steves car (manual) this is the coding I used:
Part No SW: 5K0 953 569 H HW: 5K0 953 569 H
Component: LENKS.MODUL 014 0140
Revision: --X01--- Serial number: 20120121301625
Coding: 1082140000
Shop #: WSC 73430 790 00088
VCID: 3D7A8C03AC27B7F00A3
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 800000
here is one from my car
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Revision: -------- Serial number: 90472LHQ00021
Coding: 5082104000
Shop #: WSC 00152 210 91233
VCID: 76E9C1A7C924DDA80B9
Serial number: 2443760
Coding: 820000
Alam
Do you have Cruise Control fitted as well ?
No mate, I don't have a cruse control fitted. What em left is, that I should try get the module coded at skoda dealer through VAS after installation. Because em not able to do with VCDS because of unknown fault codes and no horn operation.
Regards
Alam
Regards
Alam
Yes, I got one fitted. No idea about the coding though as this was done for me. I've not yet experienced any problems with it though.
Sarge.
Hello Folks
This is what I get when I swap the steering module 5K0 953 569 A with the module which came with car 5K0 953 569.
No ASAM data for: "EV_SMLSNGVOLWSXS" (SK35)
01 Fault Found:
365080 - ROD - Unknown Error Code
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 29882 Km
Date: 2012.03.12
Time: 11:02:44
at the end car horn stops working. Any Ideas how to fix this???
Regards
Alam
you should have used a B or H version controller
Can you check your coding for Steering Wheel & Controller, i think it should be same as Eddies.
VCDS Coding: 5082104000
MFSW Controller Module -Coding: 820000
Make sure your codes for each are as above & the horn should work.
  • 11 months later...
Coding: 5082104000
Coding: 820000
Thanks eddie.
Helping my friend a retrofit a mfsw for his 2013 octavia (not the new one).
His steering wheel control module is 5k0953549. So i ordered the 5k0953549B like you did.
Just one doubt though. What part number did you order for the airbag wiring? I ordered 3T0971584.
Did i order the right one? Or should i have ordered 5K0971584C?
Please let me know. Need this confirmation before i can go ahead with the mod.
  • 4 weeks later...
Hey guys,
I'm looking to get one of these for my Octy, but i'm not sure what I need for everything to work. I tried phoning Skoda West End Garage Parts dept but they literally have no clue!
The guy stated that as my car hadn't been fitted with it at the factory he couldn't quote or tell me what I needed.
http://www.ebay.co.uk/itm/190999802956?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Can anyone shed some light for me?
You'll need a steering ecu and the small wiring harness to connect the wheel to the car, and you'll need VCDS to code it.
All the info is in this thread and others on the forum. It's been done plenty of times by a few people, I even managed it in mine!
