ABS 01314 - 004 ERROR
Can anyone identifythis error, seem to get a judder from brake on one side, but could just be state of roads.
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS.lbl
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H05 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002145
Shop #: WSC 13765 790 00000
VCID: 81021980E7539C14
1 Fault Found:
01314 - Engine Control Module
004 -- No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 227
Mileage: 216865 km
Time Indication: 0
It shows as an intermittent condition. Have your tried clearing the DTC to see if it returns?
The code is telling you that communications between the ECU and the ABS modules have failed. It occurred once as seen by fault frequency. It does not appear to be a big problem.
By the way, if you want further help, I'd suggest and request that you pony up to the bar and buy a real interface - instead of the Chinese knock-off you are using.
