Floor boot net options
Hi,
I'm looking to get a floor boot net. Currently only have the standard 2 net system (small side net and large back net). I have the spare wheel option.
I see there's a few silver net packages available.
5 pieces net without spare (DMA 630 003) or false boot floor (DMA 630 002).
4 piece net for spare wheel (DMA 630 001)
Am I correct in saying that the floor boot net is only available in the 5 piece set?
Will either of these fit my car (with the spare wheel option)? Or am I restricted to only DMA 630 001, in which case does not contain the required floor boot net?
Edited by Hyeung
I have the spare wheel option in mine, I also use the two nets that came with the vehicle. The only extra net that I've bought is the parcel shelf net, which I use for storing shopping bags. My dealer at the time told me that the boot floor net would not fit due to the spare wheel option.
Anyone using a boot floor net (with the spare wheel option)?
The only issue i can see that the fastening points are situated under the boot floor in my case. But the corners of the net would just get secured the same way on the fastening points. Each corner of the net would probably overlap under the boot floor thou?
I'm sure someone has tried? Anyone?
Sorry - haven't really looked at the nets, apart from the 'shopping bag' one that hangs on the rails (good for keeping bottles upright!). I'll investigate when there's opportunity.
I understand that the floor of the boot sits higher up with either options
1) false boot floor option
2) spare wheel option
Can anyone tell me if the false boot floor sits at more or less the same level like the spare wheel option?
I.e such that the floor sits above the so called "lashing eyes" at each corner....the bits were the net hooks attach onto.
Just trying to figure out if the 5 piece net for the false boor floor option would be suitable (DMA 630 002)?
Thanks,
Hung
Thanks,
Hung
I believe the false/variable floor is slightly lower than the spare wheel floor.
Thanks for that.
In that case, I guess i cant see any reason why the nets for the boot floor (dma 630 002) would not be suitable
for the spare wheel option too. Just surprised no one on here appears to come across this.
I would expect them to use the same net program.
