different rear hub/brakes on FL VRS?
just wondering if you guys can help, bought a set of 4 spacers for my VRS from DPM a while back, and while the fronts fit a treat, the others dont (they are identical spacers btw) I know that MK6 GTI golf has different rear brakes, I assume the FL VRS does too, so I guess that means a different rear hub also. Can anyone tell me which rear spacers I will need?
don't know but mine fitted front and back and and were interchangeable
they should be 5*112 front and rear
the pcd isn't the issue. there's a slight difference between the hubs front and rear and depending on how the spaces have been designed it can cause fitment issues
using hubcentric H&R 10mm spacers btw
The PCD and centre bore should be the same front and rear, pre-FL and FL. In what way are the spacers not fitting? Have you tried swapping the spacers front to back? What have DPM got to say about it?
only encountered the problem the other day when I went to fit my winter neptunes, and yes obviously tried swapping front to back, PCD etc is correct, but the centre does not go the whole way over, there is a little lip inside the hubcentric bit that doesnt clear the hub on the back, but fits perfectly on the front, but not on the back, BTW, this will only apply to 2011 onwards models.
Ah,
Actually I got a set of 16mm Hubcentric spacers for my car (2012) and now that you mention it I am certain the guy that sold them to me mentioned something about the 16mm being nesseccery to clear the hub. I will try to contact him to find out.
