Survey: Fabia Vrs upgraded engine mounts - Interest?
Hi
I'm in the process of organizing a 3-piece kit of upgraded engine mounts for the Fabia vRS. The kit will be custom build by Vibra-technics, but first we need to find out how many would be interested in a kit like this.
The kit will only be applicant for the ASZ and BPX engines across the makes of Fabia, Ibiza and Polo. This is because of the 6 speed gearbox, so sorry you guys with alternative engines :o
Why upgrade?
-The tuned PDs have so much torque the engine will move around quite a bit during quick shifts and hard acceleration and several people have already had problems with early wear on the standard mounts because of this.
New mounts will be stiffer and reduce engine movement, and through proper testing only a small increase in engine vibrations should be seen.
The kit will have a prize around
