Manifold codes
Cars started stuttering a bit over past few days so took it to the local garage and 2 codes came up
17568 - Manifold temp sensor (G72)short to ground P1160 intermittent
and
17564 - manifold pressure sensor (G71) open short to ground P1156 intermittent
cars in limp mode now majority of the time
Anyone had the same problem?
easy to replace sensors?
I would first be looking to see if those sensors have a common +supply to them. Both showing short to ground may mean they have no postive supply voltage to them. Perhaps a relay or a wiring break is causing this.
I would not start by replacing sensors. I would start by getting a wiring diagram to see what is in common!
A visit to erWin for your car may save you a bunch: https://erwin.skoda-auto.cz/
You've not said specifically what car, year or model but on some models the manifold temperature and pessure sensor are in one unit on the manifold.
Edited by Chris_55
Cheers both
Is a mk1 Fabia vrs
