headlight gremlins
Evnin, my o/s headlight has started to do weird stuff . The o/s full beam has stopped working , when I have dip on and flash nothing happens on the o/s. When I put it to full beam by moving tge stalk away. The o/s light goes out completely bar the side light . What is going on. I changed bulbs to see if it was that to night breakers still tge same . Any ideas?
check the connector of the headlight....one of the pins may got inside and are not touching anymore
I'm not sure what you mean by "got inside "do you mean the pins on the H3 connector at the bank of the bulb or the headlight connector at the back.of the whole unit ?
I was quite clear when I said "the conector of the headlight"
wich is this:
Uploaded with ImageShack.us
one of the pins may got pushed inside.
Ahhh right I see, cheers for the pic to. I'll have a look in the light tomorrow. Is this a common problem?
I had it many many times...everytime something wasn't working,one of the pins got inside.
I replaced a good adjusting motor,because one of these pins
Hmmm I may have been a but rough taking it out which would explain this. Cheers
Is it a case of they just need pushed back through as in the pins rattling inside yhe unit or do the just need pulled out a bit with pliers.
I dunno mate but anytime anyone refers to gremlins it makes i chuckle :D
I hope u get it sorted matey
Goodluck :)
