Bluetooth Open Circuit
It took me 3 hours (some bits were extremely easy whilst others had me baffled for a while) but at last I have Bluetooth installed, all works fine - Maxidot showed the phone options even without any coding can make/receive calls/phonebook displays (all with an iPhone I hasten to add).
Initially I had a plethora of fault codes but after clearing these and having a run out all left bar 2 (suspect it was having the battery disconnected).
One was that the CAN Gateway had not been correctly coded - sorted by adding Module 77 to the installed list, the other that I can't get to go away is the below:
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663009948
Coding: 0A01000000010101
Shop #: WSC 00028 028 00022
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_SK35.rod
VCID: 397991B8B88BA3D026B
1 Fault Found:
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 11
Mileage: 277 km
Date: 2000.14.26
Time: 14:50:04
Any ideas?
Rest of scan is:
Chassis Type: 7N0
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 55 56 62 72 77
VIN: TMBE************
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
Part No SW: 1Z0 907 115 AF HW: 1Z0 907 115 F
Component: 2.0l R4/4V TFSI 0020
Revision: AAH18--- Serial number:
Coding: 0203000C18070160
Shop #: WSC 73430 790 00064
VCID: 79F951B8300B63D066B
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 163B601C092A00FB681106E5901E0081340800
VCID: 7CF748ACFF3956F87DD
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 BR HW: 3T0 907 044 BR
Component: Climatronic H19 0606
Revision: 00001007
Coding: 0010000002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_Climatronic_SK35.rod
VCID: 8305B3500AC7A900BC7
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 AD HW: 1K0 937 087 AD
Component: BCM PQ35 H 111 0709
Revision: AC111709
Coding: 48000AB8A05BB1C040080080110091E4430000AE724D8960808440040040
VCID: 73E56390D26719802C7
Subsystem 1 - Part No: 1Z2 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 04101 26 0601
Coding: 00D7B7
Subsystem 2 - Part No: 1Z0 951 171
Component: Innenraumuebe 008 5101
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 10: Park/Steer Assist (J446) Labels: 5J0-919-475.clb
Part No SW: 5J0 919 475 A HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0005
Revision: --H11--- Serial number: 32931229000881
Coding: 10800F
Shop #: WSC 13765 790 00064
ASAM Dataset: EV_EPHVA14SKxxx0000 001001
ROD: EV_EPHVA14SKxxx0000_SK35.rod
VCID: 3365A3909AE75980EC7
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC2CNPM3
Coding: 0020788
VCID: 3D7185A864A39FF00A3
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440LJI000GW
Coding: 5080140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_SK35.rod
VCID: 70EF6C9CAB712298D15
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 943 R HW: 1Z0 920 943 R
Component: KOMBI H05 0607
Serial number: 00000000000000
Coding: 410E01
Shop #: WSC 73430 031 00064
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
VCID: 489FE47CF361CA58A95
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7N0 907 530 AB HW: 7N0 907 530 AB
Component: J533 Gateway H47 1633
Revision: H47 Serial number: 061012F2002877
Coding: 351303
VCID: 70EF6C9CA3712298D15
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0607
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
VCID: EADBFEF40DAD58481F1
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2120
Coding: 0000756
VCID: 489FE47C3B61CA58A95
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 74 3305
Revision: 00H22000
VCID: 377D9780469FB5A0D0F
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000756
VCID: 479DE740367FC520A0F
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 1507610
VCID: 3467A08C57E95EB8F5D
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000023
Subsystem 2 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul r 0004
Coding: 00000023
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 156 F HW: 1Z0 035 156 F
Component: BOLERO 010 0061
Revision: 0A001001 Serial number: SKZ1Z3M9725961
Coding: 0D0004000001
VCID: 35619D889C9347B0C23
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 326BA694ADFD5088E71
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 3365A39052E75980EC7
I replied to your other post on this
Cheers Eddie, seen it and appears to have worked.
Thanks again
