06 Plate Fabia vRS 70k check up
Hi all,
I was thinking last night on the way home, my Fabia has just hit the 70k mark - are there any recommended/suggested things that I should be doing or thinking about doing (except usual servicing of course) to ensure it's performance and economy is sustained?
Thanks in advance, I know you guys won't let me down with the help you provide :rock:
vrsrs
Egr valve clean out?
Clean maf with part cleaner?
Clean the heater fan unside the car out since they get full of leaves - not performance but good idea!
Use some fuel cleaner in with the next tank
Give the engine a flush before its next service.
Check/topup gearbox oil.
Check for play in the flywheel for future damages
Clean boost pipes and check for play inside the turbo while there off.
Thanks Hutchysrs50 - I'm not a major techie though - any guides on doing all these bits??
