My electric fan is on all the time. I have plugged my VCDS in and the following fault shows up, but I have no idea what it means. Can anyone help please.
Car is Skoda Superb 2003 1.9TD
Address 08: Auto HVAC Labels: 3U0-907-044.lbl
Part No: 3U0 907 044 A
Component: CLIMATRONIC S B5 C 2004
Coding: 17000
Shop #: WSC 00028
VCID: 3169A9F8FB0463909EB
1 Fault Found:
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
27-10 - Implausible Signal - Intermittent
01341CU in dash panel insert on CAN Comfort -J285 -
Open circuit/short circuit to positive implausible signal
Possible cause of fault :
Wiring or plug connections defective
Control unit in dash panel insert -J218- defective
Rectifying fault:
– Check wiring and plug connections according to the current flow diagram ? Current flow diagrams and Fitting locations. – Test CAN databus ? Chapter, if necessary replace control unit in dash panel insert.
http://skoda.worksho...ndex.php?id=645
  • 1 year later...
>holy thread revival, batman!<
Did you ever fix this Nackuk?  Mine does it too and has done ever since getting the car.  No ill effect (though I think it is the reason I sometimes see some German text on the dash dot matrix display relating to the satnav not being active yet).  Clear it and it goes away for a while, then comes back eventually.
Well I solved the fan issue, that was the pressure switch for the air con failed in high pressure mode (there is a thread for it in the superb section), but no actual signal recorded on the VCDS regarding this item inparticular, I just worked it out from the ciruit diagrams.. Looking at my last VCDS readout from servicng last month this didn't come up again???
Thanks for the pointer, I'll have a look at it again.
