4x55w spot lights
Hello, I am looking for some help on wiring spot lights. I have made a roll bar for my felicia pickup and want to mount 4 55w spot lights to the full beam.
Could someone advise on what sort of relay, fuse and thickness of wire I would need. Any tips on wiring them in would be great aswell but I may resort to geting an eletricition to do it.
I can find plenty answers on the kit required for 2x55w spot lights but nothing on what is required to wire 4.
Kevin
you will need a 30amp relay but run 2 feeds from the relay to 2 spots per wire and a inline 15amp fuse on each wire from relay so if there is a fault you dont need to blow a 30amp fuse is this any help to you
