dpf regeneration
hi I dont know what I am doing wrong but my DPF warning light comes on even after a long run 200 miles in 4th I dare not use a higher gear as the light would come on sooner I have tried following the handbook instruction to clear the regen to no effect , The car goes back to the garage at least twice a month . Any ideas how I can get this to work like a normal car
Welcome to Briskoda. :) What year is your car and which engine does it have?
Hi and welcome aboard.
I had the same problem with a Vauxhall van and they said the cat needs changing, so i sold the van.
Could this be a sensor? have you had it on a diagnostic VCDS to see what the eror code is?
Hello lesmw, good luck getting it sorted :thumbup:
