central locking issue.
Hi, I know that if I have that problem it seems to go away with the engine running which would indicate the higher voltage helps. There is a microswitch that can fail causing this problem, its a little switch that gets pressed by the key when you turn it in the drivers door, there is a fair bit of info about it as the same problem occurs with MK4 Golfs as well if I remember right.
It's a pain in the arse to get at though so perhaps get the battery checked out first.
