What Would Cause The Asr Light To Stay On?
Hi all,
On my way to work today my RS started to run lumpy at around 3,000 rpm. After this the ASR light on the dial come on and the using the button had no effect on the light. Also I noticed that there was a strange whoosing sound from the engine. Could it be that the DV has failed? If so how would this affect the traction control?
Lloyd
um my asr light stays on but thats my driving... im not sure why it would stay on? have you checked the fuse?
No but when I got to work I turned the engine off and on and the light went out. I aslo spoke to my garage who said they hadn't come across this problem before. It could be a failed coilpack but the car seems to running on all cylinders. I'll see what happens on the way home tonight.
Lloyd
Hi all,
I think the problem is a failed DV? I took the car out for a run at lunchtime. And what I found out was that under normal driving conditions the car is fine. However, when pushed there is a whoosing sound (it sounds like a tyre thats being let down too quickly) and the car runs lumpy.
The ASR light didn't come on this time. My next question is how easy is it to replace the DV and what is the prolonged effect of a failed DV on my RS?
Lloyd
you will hear one of 2 noises... if the dv is jammed open then the whoosh will result in little / no boost... or the other noise will be the wastegate going mental as it will be working hard in lieu of the dv..
lloyd.. i have a std plastic dv if u need one and are out of warranty..?
Hi ffelan,
I am still under warranty but I changed the standard DV for a Forge one over a year ago. So it looks like I'll have to stump up the cash for a new DV? I am off to my local dealer first thing tommorow to get them to have a look at it for me.
Lloyd
P.S I just had a thought is it possible for the DV to stick? Jon (TaviaRS) gave me some grease to use on my DV but I didn't get round to it. I am going to try some of the grease tonight
This site has an mpeg of a "honking" diverter valve. Apparently, it's the sound made by a DV that can't hold pressure.
Can't see how this could affect the ASR - perhaps that's a separate problem? (something like a dying ABS wheel sensor?)
Originally posted by llblake in this post
Hi ffelan,
Lloyd
yes it is possible for it to stick
Just had another brainwave, it could be one of pipes from my dual ICs that has worked its way loose? I'll get the gararge to check this out at the same time they are doing a diag on the ASR light staying on.
Lloyd
FYI,
Had my car check over by my dealer and it is the DV (Forge DV006) that isn't working correctly. Because the DV wasn't working it was also tripping out the ASR!! I'll will be greasing the DV tonight with the grease supplied by Jon. Guess I should have done this sooner.
Lloyd
Yep. I do mine every 10k miles. Only takes a few minutes and saves scaring myself with warning lights on the dash :D
