engine management light
guys does the 1.9d v reg fellicia have a management light if so what vagcom set up would i need to reset it cheers.
Felicia doesn't have an engine management light..
the ecu on the diesel ones is very basic, the diagnostics functions are quite limited too, it uses an old school kwp1280 protocol so only the very basic version of vcds (vag-com) would be necessary.
Do you have a light on all the time? Detail. Position, color or photo.
i havnt got a light on only just got the car but thought if it had eml and it came on i could use vagcom to reset it rather than get stung at a garage thanks for the replies nigel
