Octavia Mk1 1.6 AVU - how do I adjust drive belt?
Hi - my Octavia gets a recurrent flat battery and although the battery itself seems OK I've noticed the drive belt is running a bit loose. Can this be adjusted manually via the tensioner unit or do I need to do something else? M
the tensioner is automatic,you can't adjust it.
If the belt is loose you need a new tensioner
I'd try a new belt on it first
