Coding Columbus to a retrofit Maxidot
Hi lads hope you can help. I retrofitted a maxidot unit when i got my 2008 Octy vrs tdi which was fitted and coded at my local dealer. I since bought a columbus unit and have it fitted a while but have never coded it correctly to communicate with the Maxidot. Has anyone done this coding themselves and care to share what exactly they did (I have access to VCDS which is telling me that the headunit isnt coded correctly :wall: ). Thanks in advance
Untucked the BAP Protocol box in either Radio or Navigation.
Can't remember exactly where it is (which byte) but its at the bottom of the window.
Just a thought based upon the above, does your CAN know that 'Navigation' is installed?
No I don't think so how do I rectify this
Sent from my GT-I9300 using Tapatalk 2
From octavia-vrs.com
CAN Gateway - Controller 19
This controller uses Long Coding, recoding should be carried out using the Long Coding Helper built into VAG-COM. Select Byte 3 and put a tick in Bit 3 to enable Controller 37 Navigation.
You must as already mentioned also make sure the BAP protocol is disabled in the columbus, otherwise you'll still get nothing since the maxidot will not understand the columbus.
Navigation Bit 3 had been ticked and i unticked BAP protocol but still no joy :@
Can you post a scan from the car? That might help see what you have installed and how it's coded.
The coding for the can gateway is:E9807F064002021303
The code for the navigation is:040004000001000100
And a fault scan:
Saturday,05,January,2013,21:45:40:10074
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: TMBEH21Z48****** Mileage: 145730km/90552miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 018 EL HW: 03G 906 018 EL
Component: R4 2.0l PPD1.2 G 9953
Revision: --H52--- Serial number: SKZ7Z0G4592327
Coding: 0000072
Shop #: WSC 29001 210 97510
VCID: 73E1DBFF6B25
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0006786
Shop #: WSC 73430 790 00000
VCID: 73E1DBFF6B25
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Z0 907 044 AB HW: 1Z0 907 044 AB
Component: ClimatronicPQ35 120 0600
Revision: 00120022 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 76E7E2EB7857
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005425502
Coding: 01880F030004140040110D000000000000087F075C000000000000000000
VCID: 71EDD1F71139
Part No: 1Z2 955 119 C
Component: Wischer 211107 022 0601
Coding: 00055223
Shop #: WSC 73430
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1MECX2
Coding: 0020788
VCID: 3D753DC71DE1
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 051 0100
Coding: 0000042
Shop #: WSC 12345 123 12345
VCID: 7F0907CF576D
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 842 E HW: 1Z0 920 842 E
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612038 Serial number: SKZ7Z0G4592327
Coding: 0003401
VCID: 397D29D709C9
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0191
Revision: H16 Serial number: 2000K07B24030A
Coding: E9807F064002021303
VCID: 346318E32EAB
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1612
Shop #: WSC 03691 000 1048576
VCID: 397D29D709C9
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Mileage: 102190 km
Time Indication: 0
Date: 2000.00.00
Time: 00:20:37
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 A HW: 3T0 035 680 A
Component: RNS-MID H42 2724
Revision: AB001001 Serial number: SKZ6Z7L8400020
Coding: 040004000001000100
ASAM Dataset: ------------------------- ------
VCID: 2E570A8BC087
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 119
Mileage: 145728 km
Time Indication: 0
Date: 2000.00.00
Time: 21:45:13
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1204
Coding: 0000756
VCID: 387B2CD332C3
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
VCID: 366722EB38D7
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 80801A085283007F3F04850540081F96907CA0
VCID: 83010B3FBB85
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Component: IRUE No Answer
1 Fault Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 120
Mileage: 145731 km
Time Indication: 0
Date: 2000.00.00
Time: 21:45:34
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000756
VCID: 397D29D709C9
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 2E570A8BC087
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 119
Mileage: 145728 km
Time Indication: 0
Date: 2000.00.00
Time: 21:45:13
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 006 1201
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 37792FEF3FDD
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
VCID: 387B2CD332C3
End ---------------------------------------------------------------------
Do you have a gateway instslation lost? Is 'navigation' ticked in that?
Also check to see if any other modules that should / shouldn't be there are correctly ticked.
Another suggestion is to 'change' the short coding manually to what it already is and then save it. Think of it being a 'refresh'. So if its '00006' enter '00006' in the short code box and save it. Don't make any other changes.
The fault code on the immobiliser suggests that this is defective! Was it a brand new retro fit or a used retro fit?
Try looking at this in Radio or in Navigation:
When found in Radio OR Radio Navigation System, check Measuring Value Block (MVB) 025.1 for Details.
Measuring Value Block 025.1 (MVB) may not be supported by all Radios OR Radio Navigation Systems.
When I get home I'll check your long coding against mine.
Whoever is doing your coding for you (assuming they have a genuine cable & support package) can email Ross Tech with the scan and details if the problem and ask for their advice / guidance.
The wiper switch fault is probably the interval switch on top if the stalk that is dirty. This function can be checked in the measuring blocks with VCDS.
It can be taken apart and cleaned (there are tutorials with pictures for cleaning the cruise control switch, which I guess would be similar).
If not, 'styler' on this forum might still have his wiper stalk for sale as he retro fitted a MFSW and no longer needed to rocker switch on the end if the stalk.
The immobiliser code is there since the retrofit. It was a brand new unit from skodateile and was fitted and coded by a main dealer.
The wiper stalk is on my to do list along with installing an updatable canbus gateway.
I re-entered the code like you said and it now works. Thanks a million for your help im so grateful :rofl: . Its still throwing up a fault code but at least its functioning
Post the new fault code / full scan and we can see what's likely to be the problem.
New scan
Sunday,06,January,2013,12:05:46:10074
Chassis Type: 1K0
46-Central Conv. -- Status: Malfunction 0010
Coding: 0000072
VCID: 73E1DBFF6B25
Readiness: N/A
Revision: 00H11001
Coding: 0006786
VCID: 73E1DBFF6B25
VCID: 76E7E2EB7857
VCID: 71EDD1F71139
Coding: 00055223
Shop #: WSC 73430
Coding: 0020788
VCID: 3D753DC71DE1
Coding: 0000042
VCID: 7F0907CF576D
1 Fault Found:
014 - Defective
Coding: 0003401
VCID: 397D29D709C9
VCID: 346318E32EAB
VCID: 397D29D709C9
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 102190 km
Time Indication: 0
Date: 2000.00.00
Time: 00:20:37
VCID: 2E570A8BC087
3 Faults Found:
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 160
Mileage: 145728 km
Time Indication: 0
Date: 2000.00.00
Time: 23:10:26
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 120
Mileage: 145728 km
Time Indication: 0
Date: 2000.00.00
Time: 23:10:36
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 120
Mileage: 145731 km
Time Indication: 0
Date: 2000.00.00
Time: 23:10:27
Coding: 0000756
VCID: 387B2CD332C3
VCID: 366722EB38D7
VCID: 83010B3FBB85
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 120
Mileage: 145731 km
Time Indication: 0
Date: 2000.00.00
Time: 23:10:07
Coding: 0000756
VCID: 397D29D709C9
VCID: 2E570A8BC087
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 120
Mileage: 145731 km
Time Indication: 0
Date: 2000.00.00
Time: 23:10:27
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 160
Mileage: 145728 km
Time Indication: 0
Date: 2000.00.00
Time: 23:10:26
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 120
Mileage: 145728 km
Time Indication: 0
Date: 2000.00.00
Time: 23:10:36
Coding: 0000144
VCID: 37792FEF3FDD
Coding: 0000144
VCID: 387B2CD332C3
The radio antenna fault will always be present on a pre facelift car, nothing you can do about that. I guess you don't have an aux input in the car, so you'll need to disable that with VCDS. The other one says intermittent, so clearing it might be enough.
The aux in is working fine this is a new fault that has just appeared since i got the navigation to work with the maxidot. I know ill always have the aerial fault code :sweat:
Not strictly true.
You can add a second aerial!
I'm almost there with that one...
As mannyo says, clear the fault codes on a module by module basis (not the single 'Clear DTC's' button on the auto scan page).
Run the car for a few days and see what faults come back.
Will do thanks a million for the help
The immobiliser fault is due to a checksum error, is common on retrofitted clusters. doesn't mean there is anything wrong just that the original eeprom has been written over
Is there anyway around this error? My dealer said that I have the same error regarding the immobiliser, but the car starts and runs just fine.
Thanks for the reply Mike! Sure, It doesn't bother me as long as it's not causing any problems. Just thinking that would it pop up in the MOT inspection? During the inspection we have to have our cars obd tested where they read the fault memory. I don't know what they read as they have their own equipment. For instance, had an malfunction bypass valve which left an error code, but they didn't say anything about it.
  • 5 months later...
I'll borrow this thread again. I have another issues and I was wondering if there's a fix for it. So, I have a 2007 pre-fl Octavia RS and I have retrofitted Columbus and Maxidot. I don't have Multifunction steering wheel. Part number for the columbus unit is:
3T0 035 680 B
HW 11
SW 4120
When installing the columbus I updated my can gateway to a newer version 1K0 907 530 L, so I wouldn't have the battery drainage issue. Coded the columbus to gateway as well so it will show the data on the maxidot. I applied Josi's fix for Skoda Octavia A5 - fix for 3xxx/4xxx software also. Before Josi's fix I would get stuck on Audio and Navigation on the maxi dot i.e. I'd have to shut down columbus in order to get back to the main menu where I can choose from MFD, Audio, Navigation, and Setup. After applying the fix I can get back to the main menu normally by pressing the up or down button on the wiper stalk.
Now my problem is that when I access the Audio menu I can't change the track or radio station by pressing on the wiper stalk button, nothing happens. It should change it but mine does nothing. Has anyone else had this same problem?
Many thanks!
Edited by Spoonie
Ok, thanks again Mike! So the only alternative is to retrofit MFSW to get it working?
  • 10 months later...
Hi,
Just wanted to confirm that a similar problem I have is related to the original post here. I had the Columbus unit in my 2009 Superb Elegance replaced under guarantee by the dealer a few weeks ago (it had developed the constant reboot problem two months after I bought the car) but since then there are no navigation options in the maxi dot display.
Everything else works fine, but is this the "Untick the BAP Protocol box in either Radio or Navigation" fix that is required? Which is a VCDS thing, yes?
Thanks,
David
